After transferring the stl file into Z-SUITE, I discovered missing holes. When I did the transfer without repair, all holes were in the right place! I check the stl file with another SW. The result: No error was detected!
could you share the .stl file? I believe the holes are too small to be printed correctly. When you slice the model without repair - it might not be printed correctly.
Hello Karolina
Yes, I will send the file to you. The amazing thing is that the same and even smaller holes are present and they are correctly taken over by Z-Suite.
AC Rotorkopf_Basic_UP.stl (1.4 MB)
Kind regards
Enrico
Hello Enrico,
thank you for the file. Our specialists have checked the model and found intersections. This means the model is faulty and Z-SUITE detects this correctly. However, you can still print the model after importing it without repair.
