Hi all, check out the print I made last night with the official 0.0.4. The tops of the back legs are really rough. There is a distinct seem on the back too. It split but that could be the white material. Overall it looks good but the rough back legs are a real mystery. The support came off real easy though. There also seems to be a pattern as you go up the main body. In other words it is not smooth.
I am off to work soon will try to check in as the day goes on. Anyone else print something like this with either Z suite yet, I would like to see your results? I will have to try another colour but I really wanted to do it in white.
I would like to add that this is still better than the best prints I personally (I have not seen them all obviously) have seen on other FDM machines. I also unchecked the fan button. Not sure if this has anything to do with it.
[quote name=The6uest]Those rough sections on the back of the legs are probably the seams. They stick out more in certain areas for some reason.
[/quote]
Ahh, never though about that. I didn’t have a lot of time before work this morning to take a good look. Too bad I split half way up too because I still could have given it to my wife as is with a little sanding.
My guess is a combination of seam and not enough air flow. I’ve seen this on a couple of my prints and experimented with swapping the fan plugs so the bottom fan is on instead of top. This provided more air flow and reduced the problem.
