Hi
wehre can i download this software? (1.7)
with 1.71 PETG dont work :(
help me please :)
thanks
Hi
help me please :)
thanks
i´m alone with this problem?
no, your're not.
i tried z-petg and other with the same problem :)
there were no changes between 1.7.0 <-> 1.7.1, it was just Quality hotfix.
Trying to print Z-PETG and get awful results,
Do you get any solution to the problem?
Im using v1.8.2
I had problems with Z-PETG and Z-GLASS. Once the extrusion chamber replaced the problem to disappeared. They come back again when I do not properly purge the extrusion chamber, the extrusion temperatures of other materials being higher I think they evacuate poorly if we do not have several loads without nozzle.
TEXT ORIGINAL
Bonjour,
J'ai eu des soucis avec le Z-PETG et le Z-GLASS. Une fois la chambre d'extrusion remplacé le problème à disparu.
Ils reviennent à nouveau quand je ne purge pas correctement la chambre d'extrusion, les températures d'extrusion de des autres matériaux étant plus élevé je pense qu'ils s 'évacuent mal si on de fait pas plusieurs chargement sans buse.
TEXT ORIGINAL
Bonjour,
I've noticed this when z-glass plugs up. It's hard to completely clear out. I had best results by removing nozzle and then doing load cycle with the nozzle off. Material slug comes out. Then putting nozzle back on and doing load cycle again.
