Can it be right, that there is no way to select an infill density below 100% for the Zortrac Inkspire?
Apart from solid infill - you may use the hollow option allows you to save liquid resin by making a model empty inside (it is necessary to add one or more drain holes). You will find more detailed information in our Z-SUITE manual.
Best regards
This is an excellent option.
There are few software that can create a mesh from a stl file. I have seen them but have not used them practically.
We are glad you like our solution
