Norton doesn't like ZSuite 0.71
I tried to start up ZSuite this morning and Norton informed me that it was suspect and removed it from my system.  Has anyone else seen this?
I downloaded ZSuite from the Zortrax web site, re-installed it and successfully processed a part for my printer, so it seems to be working OK now.
Mike
All the time.. Mine does not delete it though... It asks me what to do.  I just click ignore and run anyway.. It is the reputaion1 file or something like that?
Weird - this is the 1st time Norton has complained about ZSuite and Norton has always asked me in the past what it should do about files with which it is concerned.
Mike
We have obfuscated .exe for prevent disassembling and digging inside, AV software also cannot check our file so they use simplest way and everything which cannot be checked is reported as dangerous file. Sometimes AV software is even more stupid and is enough that same obfuscator someone used once to packing “bad” software which was reported then every other file which looks comparable is reported by AV software as this reported ‘virus’.
We have obfuscated .exe for prevent disassembling and digging inside, AV software also cannot check our file so they use simplest way and everything which cannot be checked is reported as dangerous file. Sometimes AV software is even more stupid and is enough that same obfuscator someone used once to packing "bad" software which was reported then every other file which looks comparable is reported by AV software as this reported 'virus'.
Hey Martin!! I never worry about it.. I'll take my chances.. ;)
Thanks Martin.  It seems to be working OK since the 1st problem.  Do Norton and other AV vendors make it easy for companies like Zortrax to report and resolve problems between software like ZSuite and NIS?
Mike
