Notes on storage conditions of ABS filament
Storage conditions are crucial to the quality and printing effect of ABS filaments. Here are some things to be aware of when storing ABS filaments:
Drying: ABS filaments are sensitive to moisture, which can easily cause bubbles, odor and quality problems during the printing process after absorbing water. Therefore, it is essential to keep the ABS filament dry.
Sealed container: Storing unused ABS filament in a sealed container reduces the possibility of moisture entering.
Desiccant: Placing a desiccant, such as silica gel, in the container where the ABS filament is stored helps to absorb moisture and keep the filament dry.
Avoid light: ABS filament should be away from direct sunlight, preferably stored in a cool, dry place, to avoid exposure to strong light.
Stable temperature: try to keep the ambient temperature of the stored ABS filament stable to avoid drastic changes in temperature.
Keep away from chemicals: Avoid storing ABS filaments in an environment that may release chemicals, so as not to affect ABS performance.
Regular inspection: Check the status of the storage container and desiccant regularly to ensure that the storage conditions of the filament are good.
Separate storage: If there are multiple colors or types of ABS filaments, it is best to store them separately to avoid mutual contamination or confusion.
By following the above precautions, the quality of the ABS filament can be effectively maintained and the printing problems caused by moisture absorption can be reduced, resulting in better 3D printing results.
