Hello every Zortrax users.
I am new to 3D printing.
I brougth a second hand Zortrac m200 in 2024 with Z-sense et Z-temp. Its was working great. Last week I managed to unclogged my Hotend, thank to the very good maintenance tutorial.
However I get a recurrent error#033 during the calibration step on the left down corner when i tried to print a model.
It is very strange, because I do the calibration procedure (in “maintenance”) its ran flawlessly.
I tried to follow the troubleshooting to solve my issues, but most of the steps are useless in my case, because my printer have a Z-sense and Z-temp sensor.
Tormorrow, I will put my hand on a voltmeter to test all the relevant voltage.
I will put the results here.
Have a good day/nigth.
Hello Zortrax Users,
This morning my objective was to run the printer without the heating bed to see if the problem come from this part.
Slice my model with the be temperature at 0 °C in the slicer. I use Cura (and a g-code to z-code converter. I am on linux) => The bed was quite hot as usual and i got the #033 ! No sucess
I tried to unplug the small plug in the Z-sense/Z-temp card => the printer detected the problem at launching. No sucess !
I tried to unplug the big plug on the bed => the printer detected the problem at launching. No sucess !
Because I was desperate with no more ideas. I tried to unplug both => No sucess as the printer detected that the little plug was unplug.
Hard time. I will keep you in touch.
Hi again,
I am trying to dig more deeply into my first No_Sucess try to work without the bed heating function.
I asked somebody with a windows PC to make from the Zsuite, a benchy without heating the bed…
Sucess ! My m200 is able to print without heating the bed and without the 033 error !
My next objective is to make the same benchy file with Zsuite with bed heating.
If the printer throw me the same error, it means that I have a hardware problem.
If the printer is able to make the print without error, it means that I have a software error…
