Nozzle layer thickness of 0.6mm
Hello
I’m using a Zortrax Dual with a 0.6mm nozzle for carbon-filled filaments (ABS CF and PETG CF). The only problem is that it’s limited to a 0.3mm layer thickness, which is quite thick. Could you add 0.15mm or 0.2mm thickness to the list? Because I think it’s a shame to tinker with CURA when your slicer works very well otherwise.
Thank you very much.
Hi, I was on vacation. Can you provide more details about what filament you’re using, etc.? I’ll try to help you. I just need more details.
I generally use PETG CF, ABS CF, and now PACF filaments. These filaments require a nozzle larger than 0.4 mm to avoid clogging.
However, Zortrax doesn’t offer a 0.2 mm layer height option with a 0.6 mm nozzle. Would it be possible to add this option in a future update (for external filaments)? Prints are quite rough at 0.3 mm. Thank you very much.
