Hi all,
Is there a way to adjust the number of walls in a print? I would like to improve the water tightness of my prints.
Thanks,
Hi all,
Thanks,
If you can print in shell mode, you can do up to 3 or for depending on machine. Alternatively you can print as solid, if the geometry allows. For thin walls, it’s critical to adjust wall widths so zsuite fills them efficiently. You can also try increasing the extruder ratio.
