I have a new ribbon cable, a new print bed (with fresh ABS juice), new enclosure, and fresh HIPS (having always used ABS)
And despite this, after nearly 3 months of troubleshooting and swapping in new parts/lower shrinkage filaments, I cannot seem to have a proper model print.
Any thoughts?
Did you perform a platform calibration? Try to calibrate with no filament into the hotend (unload material before calibration), then remove any filament residue from the nozzle tip.
Moreover, remove ABS juice from the small areas where the nozzle tip touches the print bed during calibration.
First of all, make sure that there are no draughts in the room where the printer works (shut the windows if they're open, turn off the A/C if it's on).
