Optimus PETG/Carbon and PETG Kevlar
Searching for strength and light weight, those were the next filaments in the Zortrax.
Optimus PETG/Carbon( https://www.filament-abs.fr/produit/filaments-petg-carbone-au-metre/)
printed with the PETG settings, speed and extrusion -10%.  I would say those are not critical and also the normal settings would be fine, however this was a good starting point. Retract and retract speed should both be increased, I am now up to 1,7mm and 40 speed. Print temp 240°.
Surface is excellent, one of the best I have ever seen, pretty smooth, no layers visible. Density of the printed object was calculated with 1,06, which matches the advertized value 1,05.
I printed a float segment with 1 shell, and the layer bonding turned out to be much weaker than the Zortrax PETG.
So this filament should be great for volume models who need stiffness, a perfect surface, and light weight.
Next was PETG+Kevlar from https://www.atome3d.com/products/petg-kevlar-jaune-nanovia-1-75mm-500g
Same settings as above, only temp increased to 260°. Also a very fine surface, no layers, however just not as smooth as the Optimus PETG. The one shell float segment was not as stiff as with carbon. Weight is lower - 11,4 gramms compared to 12,8 gramms of the Optimus - and the kevlar seems to mesh better with the PETG, layer bonding is considerably better than with carbon.
Left kevlar, right carbon, which already has a crack by just bending it gently:
4610
regards
Andi
Addendum: The same approach as with the Eumaker+Carbon was successful - reduced extruder flow, increased print speed. Basic is the PCABS setting, extruder - 50, print speed
+40. Temperatur 253°, fans off, layer 0,19.
Layer bonding is much better, the PETG+Carbon turns into a tough shell.
Also the Kevlar filament improves.
Recommended ;)
regards
Andi
First of all, I would like to thank goldenage for sharing its parameters, so I tried to print with Formfutura Carbonfil.
These are my settings:
Printer speed: -5% (but I'll trying with -10%, sometimes extruder skip)
Flow ratio: -10%
Extuder temp: 260°
Platform temp: 55°
Retraction speed: 40mm/s
Distance: 1.7mm
With these settings I succesfully complete a small print.
5262
