I see Z-Flex is coming, but wanted to know if there is a filament I could use to print a gasket.
Printing anything to be air or water-tight is not very easy unless you do some post-processing to it.
Can you recommend a post processing step to improve the air seal on a ABS part, or between connected parts.
Sand or file surfaces flat and use Acetone to help seal the surface.
i have done tests and the best solution to have airtigh pieces is to use acetone
I suggest printing an o-ring groove and then you can buy 10 feet of cord-stock from Amazon or eBay and make an o-ring using Cyanoacrylate and accelerator.
