Since I'm a Linux Mint user the only way to use Z-Suite is via Oracle Virtualbox.
Version 1.2.2 was the last version I was able to run with Virtualbox and Windows XP .
While I do not think Zortrax will ever do a Z-Suite version for Linux, it would be nice if at least Z-Suite would still maintain a compability with Virtualbox.
I believe that 1.2.2 was one the latest Z-Suite versions that works with XP at all, since its no longer supported by Microsoft, we cant guarantee that will work either, mostly due to *.NET version.
The older zSuites ran OK under Wine... that SSD corrupted and had to be replaced ;(
v 1.7 gives the following crash
System.IO.FileNotFoundException: Could not load file or assembly 'Zortrax.View, Version=1.7.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.FileNotFoundException: Could not load file or assembly 'Zortrax.View, Version=1.7.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies.
I made several attempts with most of z-suite versions up to v1.7.2.1
guest is W7x64 with 3D acceleration enabled, host is ubuntu 16.04
z-suite up to v1.1 are 1st class citizen, no issue at all, rotate/zoom very fast
it seems that all newer versions containing chromium browser embedded via EO 3rd-party components are having (at least visually) the same incomplete redraw issue
