But i want try another solution, similar than your.
I attach some shot, i think that is clear what i want do.
Hello! The yellow part is your model. To your model you attach a sacrificial rim; the orange part. You may stiffen the rim with ribs if you like, but shouldn't be necessary. If you use ribs, make sure to leave enough space between the ribs and the model wall so you can get a knife in between. The rim must be rather thin near the model walls, 1mm is enough. If it is thicker (where you cut), you will see the internal mesh when you remove the rim. The blue part is the autogenerated raft from Z-suite and the grey is the perf. board.
Second pic. is with ribs, made fast, don't worry about the dimensions and the shape. You make those as best suited for your model!
Hope it works for you!
I get from you that the rim shouldn't extend under the part right?
what u are doing defeats the purpose since ur part is now not connected to the raft. the problem you had will now repeat on the raft above support. I think that is why Z-renegade is having a laugh
Correct, if you do that you will add thickness to the bottom of your part. See pic for clarification.
Yes that's true but i'm farther from the heated plate and the retraction will be different respect supported to the plate and i want try what happens.
Z-renegade who ?
Z-renegade who ?
having more heat in the bed helps reduce warping and that is the purpose of heated beds as I know, maybe your idea will work so please tell if it does.
it's your print and u can try whatever you want. I'm not saying other wise. I now remember doing something similar with a part I printed before. Here is the part, you can see there is a protruding part that was printed on top of support and it warped considerably.
2779
