Hello all
so we have difrent prints white the PCABS bad nating is good we have scratch or brocken part s after print
we have change many things and we have no idee :-(
is some peopel white experiments and print s white the new PCABS ??
we have picture from 2 parts
first a conector nod work
second is a whater test Turbine bad this noch work and Problem is after print +/-10m
we have a M200 V4 white new Hotend V2 and all Option and we have a Temp Controll Print Room 22°C
any Idee ?
Marcin
April 8, 2016, 7:24am
#2
Z-PCABS has enormous shrinkage, I would try lowering infill, there is nothing wrong with your printer its just material itself. Is the last photo yours? Have you got Side Covers installed?
axel
April 8, 2016, 8:08am
#3
I use PC-ABS to print these parts : layers of 0.14 ; infill SOLID ouFULL ; normal speed ; AUTOFAN
There is no deformation. Very nice and very smooth material that looks very resistant.
Very happy with this filament !
I heats a T ° +/- 35 ° to 40 ° in the Zortrax with an electric heater and a thermostat
iH8u
April 9, 2016, 7:30pm
#4
You really don't need hard infill with PCABS, how Marcin said, it has huge shrinkage.
Usually with other printers we print solids until ≈300x300x300 (mm) and we don’t use more the 20% of infill.
axel
April 10, 2016, 9:08am
#5
Yes, I know there are many shrinkage with the pc abs , but I need to have very rigid and very resistant parts .
And there is no problem to print with solid infill for this object
