High,
does somebody know a source for the pinion of the extruder motor? Since I use a lot of carbon filled materials it shows some wear.
regards
Andi
High,
regards
Andi
I think that Zortrax sells that as a spare part.
The sprocket wheel is not being sold as a separate part.
The whole extruder motor should be purchased.
Really? He has to spend $70 for a motor just to replace a 50-cent sprocket?
Zortrax has small peculiarities on many things, fortunatelly this part can be found somewhere else.
In a not to distant future it would be great however if Zortrax themselves sell every single part as a spare.
Hello, if you are still around you mention this part can be found elsewhere…I just had to spend $85 { with stepper motor} to get the pinon wheel, do you know where a good one is sold?
Hello I am wondering did you ever find a quality aftermarket sprocket for the M200 extruder? I am seeking one as Zortrax only sells it with the motor, very expensive. I did get one straight out of China but it is not of good quality.
I have not the need for a spare pinion yet, but the ones I found were different manufacturers on aliexpress.com so they are also from China unfortunatelly.
