Platform Offset
Good morning,
I don’t know what it is the function of this option. Couls someone explaind me about it and when it is usefull to use it?
Thanks.
Hello @Sants,
in general, this option allows you to set the platform at the correct distance from the nozzle. For example, if the printer has difficulties with printing the first layers of the raft (paths are barely visible and the extruder motor sprocket wheel stutters) - you can lower the platform. On the other hand, if the platform is too far from the nozzle - models may warp. In order to avoid it, you need to slightly move the platform up. The offset should be set if you are facing some issues despite running manual/autocalibration.
Best regards
