Hi, we recently change the wire of the 300 (normal) and heat bed ; when we try to align the platform continues to going up pushing the extruder ; what can cause this? what can we check in order if see what it is? we already sand a little bit the contact point. thanks,
Hi!
Please go through this manual
Let me know if you found a solution.
Kind regards,
Marcin
hi, we did all the items , everything is OK according to the guide , any other test to do? thanks
Please contact us via support form and provide all measurements you did. We will look further into the matter.
