Polyhedron
Manufacture of a polyhedron composed of 180 triangular perforated faces.
All the parts were printed on the Zortrax M200 and on the Witbox (equipped with a heating plate) with ASA filament to be installed soon outside.
For those who like numbers :
- Diameter: 90cm
- 180 triangles
- 92 summits
- 540 screws!
- + / - 4.1 kg of ASA
- printing time:> 500H
4889
another picture
the family is growing !
after the second :
4891
third polyhedron with 320 triangular perforated faces :
4890
Hi Axel,
What are you using to screw the bolts in, thermal inserts, embedded nuts, … ?
Roel
Triangles and connectors are in ASA (for outdoor application). There are 3.9mm holes in the connectors to hold the screws that are stainless steel M4 / 8 : it's enough for these decorative objects that have no other functions.
The screws themselves thread into the plastic. It does not take force to screw them and not exaggerate the tightening !
There are also small tenons to guide and position the triangles on the different faces of the connectors (connectors with 5 or 6 faces depending on the case).
The faces of the connectors perfectly orient the triangles in the right direction.
To get an idea, the red connector is 30mm in diameter.
4892
