I’ve been using my M200 for about a year and a half with no problem and today during a print it shut down mid-print. I checked my endstop and everything else and everything was working properly. I’m certain at this point that it is the power supply or even the cable.
When I hold the cable in a certain position it turns on but still turns off after a while. I assume maybe a fuse is blown as I do hear some electrical discharge when I tried turning it on. Also, the female end of the power supply gets unusually hot so I’m thinking it could be melted ports that are causing it to overheat?
If this is the case. how can I go about safely troubleshooting/ fixing the issue? I am an electrical engineer and have the tools to do it myself however I do not want to go into it without support from an admin on this forum as I don’t want to cause any permanent damage.
Any help would be appreciated.
