Issue:
I noticed that my prints did not have infill even thought I was selecting it. After a number of failed printers I decided to troubleshoot and noticed that on 8/21/2019 Z-Suite was updated to 2.11. After downgrading to 2.10.3 my printers had infill again.
For testing I used the x/y Calibration Test Block found here: /www.thingiverse.com/thing:570554
Print Settings:
Estimated print time: 6h 26m
Material usage: 9.99m (24g)
Printer: Zortrax M200
Profile: Last settings
Support type: Automatic
Support: 30°
Material: ABS-based filament
Nozzle diameter: 0.4 mm
Layer: 0.09 mm
Quality: Default
Infill: 90% (I know this is a lot on infill. I usually print about 30%. I was just using 90% for testing.)
Image:
Green = Z-Suite 2.10.3
Red= Z-Suite 2.11
Theory:
Z-Suite 2.11 added the ability for “hollow” infill for resin prints. Maybe this is related?
From 2.11 Changelog:
Introduces new infill type for Inkspire – Hollow – you can adjust the wall thickness and infill density, and add drain holes in a model’s structure,
-MattsShack
www.mattsshack.com
