Hi
Is there a way to recover from power loss on the m200 plus FW 2.5.12?
If it is available, Is it something that is enabled automatically and where can I find any documentation/explanation on how to operate it
Hi @HarelBoaz,
I assume you do now own the V2 device which is equipped with Blackout Response System (a system which saves the printing progress in the device’s internal storage so that it is possible to resume the printing from the same spot after a power outage). As for V1 units - you can only resume the print when the failsafe error occurs. After restarting the device - you would definitely see that the progress has been saved, as indicated by the red “resume” button (just as if the print progress has been saved).
Best regards
