I'm trying to print an almost flat sphere (see pictures) and I wonder is this the best I can get or I'm doing something wrong. The top is quite ok, layers are very visible but I guess it's hard to avoid It on shape like this. The biggest problem is the bottom side, I've tried different support and fan settings but It does not make any difference. Maybe You people can give me some advice?
The top looks normal. I don’t see any support marks on the bottom surface. You should try a high support angle that creates support over the whole width and set the fan to 100%. Shallow angles on the bottom are always difficult on a FDM printer
