When printing objects with Z-FLEX material from a spool it was a little bit tricky to insert the material in the tube on loading the material. I have seen that Z-FLEX is included in the printer firmware being supported to load from a cartridge. Do you have exerience with this combination, do you support this or is it even critical to load?
Thanks in advance.
