This week my printer when doing a print, she stopped twice pulling the filament.
It seems the filament is thinner and the motor can’t pull it… But i tried with other filamens that already printed smoothly but i had the same problem.
I replaced the nozzle too, but no success…
But if i just Load the Filament sometimes he come out without problems and other times the motor keeps rotating but the filament don’t come out, the gear keeps can’t “force” the filament going down…
Two ideas. Maybe it's too much friction from the tube / spool holder combi. Try to feed a piece of filament directly into the extruder to see if that works.
Favorite idea: Check your extruder gear, maybe it needs cleaning. There is a support document in the support area that shows how to do it.
It may be the filament itself. I just had some rolls replaced because they were too thin to get fed through the feeder. I mic'd them between 1.54 and 1.62 when it should've been 1.75 +/- 5.
Granted the filament I had replaced was not Z series and hadn't had an issue with Z filament except before the V2 hot end and Zglass because the V1 nozzle was too small for the Zglass to fit through and it would just skip.
I'm sure you checked all the screws to make sure they are tight for the electrical connection and the thermocoupler.
That sounds like you have an electrical problem with your printer.
Either there is no voltage coming from the controller or the cabling is broken somewhere.
If you have some electronic skills you could measure the corresponding pins at the ribbon cable connector on the motherboard and go upwards from there.
If you find the ribbon cable to be faulty, this can cause many other errors too.
Just to re-confirm, the top fan needs to be ALWAYS working with the printed Turned ON, right?
Yes, the upper fan starts after you switch power on and the firmware has initialized ( the menu displays) or you wake up the printer from standby for firmware >= 0.0.8. And it runs until you switch it off (or it goes to sleep fro newer FW).
The cabling changed between the revisions, new cables don't show colors, using new cables with old hardware destroys your TC controller.
Use the following schematics to measure corresponding PINs from the connectors of the extruder PCB (fans, heater, TC, motor) to the connector of the extruder cable and then from there you can locate everything.
