I have submitted this to support but thought I should try here as well!
I just updated the firmware on my M200 so that may be the cause of it but I went to print out some parts today and the top surface seems to have issues bridging the gaps in the infill(set to medium). There are 4 identical parts being printed and all of them have varying degrees of the issue.
The attached picture is much better than me attempting to describe it any more :).
I have seen this issue before when printing with Z-ULTRAT but having the print profile set to ABS but I verified that it was set to Z-ULTRAT so that is not the issue this time around.
I've seen the same sort of bubbling on the top surface of my ABS parts. It seems to be worse with extended use. I'm guessing that it's either due to a problem with Z-Suite 1.40 or 1.41 or I have some sort of fan failure. Z-Suite won't let me revert to an earlier version and I haven't had time to mess with the fan so there it sits.
Your printer seems to print too hot. Right now I experienced the same issues, think my ribbon cable is dying again.
Could be that the temp reading of the TC is not stable and causes overheats. I can read the actual temp range on my Z-Temp and know it was too high, you could measure from a test point on the controller.
If you changed something on your hotend lately, maybe the TC is not seated correct (just another probable cause).
You pointed me in the direction of looking at the fan. I noticed a while ago it sounded like it was stuttering and I just went to turn the unit on and the fan is hardly moving at all. Every couple of seconds it looks like it is trying to turn and then gives up.
If this fan is dead I am guessing that would cause the pillowing that I am seeing correct?
I will have to take it apart and see if it is the fan itself or its connection.
I set up a simple rectangle test print and it had the same issue. I noticed during the top layers I did not hear the fan spool up at all like it normally does.
I am guessing this could be causing the issue? As for why it is not spooling up I have no idea.
I also noticed on the top fan the insulation of the black wire had melted and was exposed. I cleaned it up and added some electrical tape.
