Printing problem - unsticking :(
Whats going wrong. At begin (when printer was new) there was no problem. But now i have problem like this:
https://www.dropbox.com/s/2vwwsprgv6ln9rp/2015-06-29%2009.25.05.jpg?dl=0
Make a mix of ABS and acetone, viscosity like milk, and smear it with a cloth over the plate. I avoid the metallic areas, as you need contact when calibrating. Cover the side openings in the printer, not on top. You can also put the printer inside a big cardboard box, works just as well.
Or is it the black stuff you are worried about? Cleaning the nozzle will fix that.
Good luck!
Thank you :)
Here's a helpful tutorial, which should help you in this case: http://support.zortr...drome-solution/
