Printing problem - wavy surface only in one direction
I have problem with wavy surface only in one direction. Any suggestions where is the problem?
It looks like you have play in this axis direction. It’s probably the pulley grub screws that need to be tightened.
ok but which one? Left or right?
Check the motor on the right..
Check all of them to be safe.  :)
@pioo,
Your printer need axis maintenance - please see video: http://support.zortrax.com/hc/en-us/articles/201002262-XYZ-Axis-Maintenance
Here you can find some maintenance tips - http://support.zortrax.com/hc/en-us/articles/201810472-Maintenance-Guide
Thank you Filip, those links were extremely helpful.
