Has anyone printed the arm using ABS? Is the shrinkage factor the same as Z-ultraT?
Guy
Guy
I've printed it in Z-ABS and all the parts seem to fit fairly well. As usual, parts that needed support had a degraded finish at the top of the support and there was a little bit if warping on the larger footprint parts that were moderately tall. I think that I printed most of them at 0.19 mm resolution.
I don't know if the shrinkage factor is any different than Z-Ultrat and haven't tried to fit any stepper motors to it yet. I did test one of the bearings and that fit into it's recess just fine.
Thanks MichaelHenry,
I printed the Arm-1-upper in ABS
Resolution .014
Offsets
Outer .1
Holes .2
40mm stepper motor was a tight fit, but its OK.
Guy
What are the + and - numbers 3,4,5 mean (anything?)
Guy
Octave has both the V1 and V2 arms printed and currently the V1 is fully set up with a ramps board. The V2 is sitting in a box somewhere for the time being.
