Printing stops and stays at 23%
I have an Inkspire and it worked great until this print.
My print simply stops at 23%, I did it twice to check. The platform is down like it was printing, but just infinite. When I click pause or stop, it waits to stop indefinitely. I am forced to stop manually with the switch. I have 2.11 version of Z-suite, I will try to update but I’m not sure if this is the problem.
I use Pro black resin and the same essential parameters as I use usually.
Do you think the STL file could stop like that a printer if it was corrupted ? Do you have other ideas?
Here are the models and settings which stops at 23%:
Does the printer stop while printing this specific model only? Have you run other prints? Can you pass me the file for checking?
Yes this one only since I have the printer. I printed several other objects without problems.
I did the setting from the begining in Z-Suite once again and it works, The printing worked, so the problem came from the Z-Suite file/gcode.
Here is the file with a problem which stopped at 23%: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Thank you for the update and the file. I am glad to hear the problem did not occur again.
no problem, could you test it on your printer and tell me if it bugs for you ? and maybe what was the problem.
Dziekuje
Pozdrawiam
Sure, I will test the file on our printer.
Thank you as well.
Pozdrawiam :slight_smile:
I just wanted to update you on this case - the print did not stop at 23%, it went fine.
