Printing support problem
Hello guys, need help!when it starts printing, it does not create the central part of the base. It could be a problem of the platform boarded? The motor of the extruder was just cleaned
thanks
The ribbon cable is most likely broken.
Hi, the problem is only in the middle of the platform. If I stamp an object on the sides everything works perfectly. I have clean the pulley on the motor shaft and the platform.
Some wires in ribbon cable might be broken, so it loses conection on specific places.
Some users had this problem before. Contact support.
thanks
Did you try to autocalibrate the perforated plate? What value do you get for the central point?
You could try to straighten the perforated plate (http://support.zortrax.com/hc/en-us/articles/201932351-Straightening-Perforated-Plate)
Hope this helps.
If perforated plate was convex, holes would be filed with plastic. :)
1409
Two possibilities:
  1. Ribbon cable is broken - contact with support@zortrax.com (but before, check point 2)
  2. You can try make a platform maintenance, here is the link:
a. http://support.zortrax.com/hc/en-us/articles/201932181-Cleaning-the-Platform
b. http://support.zortrax.com/hc/en-us/articles/201932351-Straightening-Perforated-Plate
BR,
Igor
Just keep printing…if the area still has no extrusion after a couple of layers above the raft, then you have to fix or replace the ribbon cable.
the only problem is only where the filament touches the platform, if I keep printing all is well!!!
so I think it is not the ribbon cable....what is the problem? :)
Clean underneath the perfboard…it seems to be bowed up and that’s why the nozzle gets blocked there. Does the extruder stepper click in that area?
Your platform is probably bowed or between the platform and heatbed are there any remain of material.
