I had to try this version of Z-Suite to get lower adhesion between raft and printed parts.
These are my findings for Z-ABS profile in 0.19mm layers:
1. hotend heats to 175C
2. hotbed starts heating
3. file is checked (FW 0.0.5), first time I've seen this message
4. hotend heats to 260C
5. raft is laid (still 260C)
6. part starts printing, still 260C
My conclusions: (print not finished yet, will see results in the morning)
- filament performs better, at least for me
- I will probably mount the sides, just to be sure since the temp is 20C lower on the extruder (same as Z-HIPS in 0.0.9.5)
- Suite tries to place the seam on the front side of the print :( so I turned it 90 degrees; 0.0.9.5 did hide the seam better
- speed in 0.0.6 is almost double than in 0.0.9.6 with same settings (normal)
- slicing is much faster in 0.0.6
