I’ve recently got an M200 and so far only used Zortrax’s own ABS with very good results. I’ve tried some PLA the other day, namely PLA and PLA+ from rigid.ink, results where terrible but I’ve blamed this on the material settings in Z-Suite. Having done more research though I can see that using PLA, even Zortrax’s own PLA Pro isn’t a trivial task on the M200:
Can someone explain why the need for a brand new hot end just to print PLA? isn’t this the easiest material to print with? I’ve never seen any other manufacturers suggesting brand new hot ends for PLA prints, so I’m just trying to wrap my ahead around what makes the M200 different.
Using rigid’s PLA I’ve had no major issues with extraction, but I’ve taken the entire hot end apart and cleaned the nozzle properly before loading PLA (btw this hot end has been used for a long time with ABS). I’m now contemplating getting Micro Swiss hot end for all filament types, but I’m still not 100% the machine can handle PLA without issues.
Regards,
T.
