I would like to print Z-Ultra T with my M300 thanks to the possibility of using external material, but I absolutely don't know what settings can be used.
Does anyone has ever tried it or can give me some advices ?
ABS and UltraT profiles are very similar. Mainly the extruder temperature is a bit lower for UltraT (260° instead of 275-277°C).
So while I didn't try it myself, I would expect that using the "ABS based" profile and lowering the extruder temperature to 260°C should give good results.
