Prints randomly hanging up?
Inkspire users: I have had multiple instances where my print will just hang randomly during a print run. The timer just repeats and no more images will flash to the LCD. This is on prints that have run successfully before. I thought this might be a USB stick issue, so I used a brand new, high-quality Sandisk stick and still had this happen. It is MADDENING because there are not any log files written when this happens, so I have 0 documentation to report back to Zortrax. Anyone else having this problem? Note: this has happened on both Zortrax and third party materials.
Hi!
Do you have the latest firmware installed?
https://support.zortrax.com/downloads/firmware/?printers=inkspire
Please send me the zcodex files that failed this way, so I can do a test for you and check if the printer behaves the same way on my side.
Thank you Marcin. I sent you a PM.
