The printer turns on every other time usually freezes. Strange color freezes on the screen. I tried to change the firmware did not help. There are no people in Russia who can help. I will insert a photo .
Hi @PojiloyUdav,
please refer to the troubleshooting manual. Check all connections and remove the signal adapter if it is installed. Also, make sure the LCD display through board attached to the motherboard is firmly secured.
If there is no improvement - contact us via support form as the Android PCB may require replacement.
