Hi!
can anyone know what is the problem when i load this filament https://www.3djake.com/3djake/ecopla-white-black-economy-set
in printer and its shut up and start clicking gear.
i think it is stuck in the nozzle and can not pass filament…
thanks
Hi, @goran.
Take a look at our Z-PLA Pro tips, they can be applied to external PLA-based material as well.
Have you been using this hotend for other materials as well? If yes, I would recommend to replace it with a new one that you’ll be using for PLA materials only.
Do you have original hotend? Swap it to Microswiss and switch only nozzles with materials. I mean here, that if you will swap for example from ABS to PLA or vice versa you will swap nozzle too.
Hi!
Yes it is original zortrex.
Can you give me a link for Microswiss
I am new in 3d printing
Put on google “microswiss hotend for zortrax m200”
Hey… thank you… I will try that
Settings for 3djake ECO pla black printed with Zortrax M200 with hotend v2
First of all select External material/PLA-based filament, then change:
Print speed: -8%
Extrusion temp.: 254
Platform temp.: 30
I know that the extrusion temperature is very high for the PLA material but it works fine for me and I have a new thermocoupler and Heater.
