I am trying to build multiple copies of a part i designed.
I orientate and create supports for x1 part and all is ok built perfect.
I duplicate the part to build x2 same part and software gives completely different supports missing out a lot of features that need support - Large disc at top of part-
If i build x2 with this support the build will fail.
I suggest you send your files to Zortrax for analysis - you are right that the slicer behavior does not seem correct and it should not require 80 degrees for these parts.
