Problem with fine print on Zortrax M200
Hello everyone,
I am new to the forum. I start 3D printing with a Zortrax M200.
My problem is this:
I can not print very thin cables. The file is attached.
Can you tell me if the file is too fine for the M200 or if I have to modify the file on Z suite?
Thank you for your help.
What is the thickness of the cables?
It is preferable that the thickness is at least 0.8 mm
I do not know I do not yet master the design software.
This is a file that I downloaded. How can I make to grow their diameters?
Thank you
Your wall thickness is .18mm. This is too low. Zortrax will not slice (the process of converting a 3d model into layers for the printer to understand) anything below .5mm.
Learning to increase wall thickness is fairly easy once you start to learn your software of choice.
I recommend you start with something like Sketchup, which is free. The tape measure tool will tell you how thick your walls are, you need to work on making them at least .5mm. Youtube is the best place to go for tutorials.
Thank !!!  :)
Here you go SP122, check this video i made for you: https://www.youtube.com/watch?v=K0z4cZACtbo&feature=youtu.be
Good evening
Good evening
Big thank ! ;-)
