This is a simple test file I made to understand wall thickness.
On the left part the wall is 0.6mm, on the right is 0.5mm.
I was expecting Zsuite to turn everyhing red after the wall check with nozzle 0.4mm, instead everything was green. So I let it print the test.
I got 2 exact parts with about 1.14mm wall thickness
I’m confused about the validity of the check, it seems it always print at 1.14mm
Thank
Roby
prova.stl (139.7 KB)
