Hello
I am new in 3d printing. I noticed that when I am using long support I have deformation on 3d printed model. Support is disconnecting without the problem . I have 35C inside printer and default Z-ASA settings. Is it normal behavior or there is need to change settings or fix something with printer hardware ?
Pictures :
Pictures of 3d print
Hi @Tengrom,
Yes, areas where support structures adhere to a model will always be affected. Depending on the model - either a different orientation, or increased support angle (preventing from overhangs) might improve the final result.
