Since latest Update of my IMac I have no Profiles in ZSuite anymore. Can you tell me where the folder is on the Mac for the Profiles-Material? Then I could bring them back via TimeMachine.
Hello Jens,
the profiles can be found here: /Users/USER_NAME/.config/Zortrax/Profiles.
Thank you, I have found the folder. The files are still in the folder but dont appear in ZSuite.
What can I do?
what Z-SUITE version are you using? Please note that in order to make use of the previously saved printing profile - you need to choose the right model of the printer, material type and material group (Zortrax/external). For example - it is impossible to use the given profile in the single mode if it was saved for the dual one (even for the same material).
