This seems to be working. I will update it if I need to. I am running Firmware version: 2.7.4.
‘Zortrax M300 dual.ini’:
generated by PrusaSlicer 2.9.2 on 2026-01-31 at 16:19:44 UTC
autoemit_temperature_commands = 0
bed_custom_model =
bed_custom_texture =
bed_shape = 0x0,265x0,265x265,0x265
before_layer_gcode = G92 E0
between_objects_gcode =
binary_gcode = 0
color_change_gcode = M600
cooling_tube_length = 5
cooling_tube_retraction = 91.5
default_filament_profile =
default_print_profile =
deretract_speed = 0,0
end_gcode = ;- - - Custom end G-code for dual extruder Zortrax M300 Dual - - -\nM140 S0.0000 ; disable bed heating\nM109 S0.0000 T0; disable hotend 0 heating\nM109 S0.0000 T1; disable hotend 1 heating\n\nG1 X0 Y0 F4800 ; move to 0x0 positon\n\n;- - - End of end G-code for dual extruder Zortrax M300 Dual - - -
extra_loading_move = -2
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_colour = #B4721A;#1D28A5
extruder_offset = 0x0,0x0
gcode_flavor = marlin
high_current_on_filament_swap = 0
host_type = prusalink
inherits =
layer_gcode =
machine_limits_usage = time_estimate_only
machine_max_acceleration_e = 10000,5000
machine_max_acceleration_extruding = 1500,1250
machine_max_acceleration_retracting = 1500,1250
machine_max_acceleration_travel = 1500,1250
machine_max_acceleration_x = 9000,1000
machine_max_acceleration_y = 9000,1000
machine_max_acceleration_z = 500,200
machine_max_feedrate_e = 120,120
machine_max_feedrate_x = 500,200
machine_max_feedrate_y = 500,200
machine_max_feedrate_z = 12,12
machine_max_jerk_e = 2.5,2.5
machine_max_jerk_x = 10,10
machine_max_jerk_y = 10,10
machine_max_jerk_z = 0.2,0.4
machine_min_extruding_rate = 0,0
machine_min_travel_rate = 0,0
max_layer_height = 0,0
max_print_height = 300
min_layer_height = 0.07,0.07
multimaterial_purging = 140
nozzle_diameter = 0.4,0.4
nozzle_high_flow = 0,0
parking_pos_retraction = 92
pause_print_gcode = M601
prefer_clockwise_movements = 0
print_host =
printer_model =
printer_notes =
printer_settings_id =
printer_technology = FFF
printer_variant =
printer_vendor =
printhost_apikey =
printhost_cafile =
remaining_times = 0
retract_before_travel = 2,2
retract_before_wipe = 0%,0%
retract_layer_change = 0,0
retract_length = 0.7,0.7
retract_length_toolchange = 10,10
retract_lift = 0.4,0.4
retract_lift_above = 0,0
retract_lift_below = 0,0
retract_restart_extra = 0,0
retract_restart_extra_toolchange = 0,0
retract_speed = 30,30
silent_mode = 0
single_extruder_multi_material = 0
start_gcode = \n;- - - Custom Start G-code for dual extruder Zortrax M300 Dual - - -\nG90 ; use absolute coordinates\nM83 ; extruder relative mode\n\nM900 T0 K0.00 ; set linear advance K to 0 for extruder 0\nM900 T1 K0.00 ; set linear advance K to 0 for extruder 1\n\nM140 S[first_layer_bed_temperature]\nM104 S[first_layer_temperature_0] T0 ; set right nozzle heater to first layer temperature\nM104 S[first_layer_temperature_1] T1 ; set left nozzle heater to first layer temperature\nM190 S[first_layer_bed_temperature]\nM109 S[first_layer_temperature_0] T0 ; set right nozzle heater to first layer temperature\nM109 S[first_layer_temperature_1] T1 ; set left nozzle heater to first layer temperature\n\n;- - - End of custom G-code for dual extruder Zortrax M300 Dual - - -\n\n\n
template_custom_gcode =
thumbnails =
thumbnails_format = PNG
toolchange_gcode =
travel_lift_before_obstacle = 0,0
travel_max_lift = 0,0
travel_ramping_lift = 0,0
travel_slope = 0,0
use_firmware_retraction = 0
use_relative_e_distances = 1
use_volumetric_e = 0
variable_layer_height = 0
wipe = 0,0
z_offset = -0.4
