ABS is not known for being the whitest material… It is naturally whit-ish, but injection, extrusion, thickness, shape and all easily affect the esthetic of the color. I guess you could try another reference of ABS filament but even then I’m not sure you would get the white you want. At least, you can try pigment-colored ABS filament from another brand.
Might spraypainting them be an option? It is timeconsuming and cumbersome to do on all those seperate parts.
I am actually competing with Shapeways here, which (by the nature of their printing process) has a whiter white. The advantage I have over Shapeways is the speed of delivery.
If you order from Shapeways you get an email after almost two weeks: “Yes, we started printing your order”. So that is not difficult to beat :).
I too noticed the white I received wasn’t as white as the Zombie Hunter Head that came with my printer. It is white enough for me but it is a little different shade.
[quote name=The6uest]I too noticed the white I received wasn’t as white as the Zombie Hunter Head that came with my printer. It is white enough for me but it is a little different shade.
[/quote]
It is exactly same material Just Zombie Head is very ‘solid’.
Bluevoid looking for material of colour as for example white used in kitchen equipment.
Just pm-ed you the bigger picture. (sorry I am not allowed to show this on this forum yet)
To add: another color than white is not possible as the device with the printed part is in sight and needs to be as unremarkable as possible.
It will be used in a hospital like environment.
[/quote]
You can use Up! (Delta Micro / Afinia) official OEM filament. It uses 260C extrusion temp and in white color it is “frosty”, i.e. very white, which I think is what you are looking for. I have tried it on the Zortrax and it works well.
[/quote]
Julia
[/quote]
Julia the problem is that it is same colour as Z-ABS
bluevoid need is something like a the cheapest Chinese ABS white - no frosty, no transparency, something to fit a colour of power outlet I saw this kind of white colour in el cheapo filament which I tested once.
I have them side-by-side here and the Up white is noticeably “whiter” than Z-ABS, or put another way, Z is more yellow than Up. I have some other 3rd-party “natural” un-colored ABS and it is similar in color to Z-ABS, but the Up filament is much whiter; I don’t know if it has color added or not.
[quote name=JuliaTruchsess]I have them side-by-side here and the Up white is noticeably “whiter” than Z-ABS, or put another way, Z is more yellow than Up. I have some other 3rd-party “natural” un-colored ABS and it is similar in color to Z-ABS, but the Up filament is much whiter; I don’t know if it has color added or not.
[/quote]
Interesting… good to know before second batch is manufactured.
