Is there any chance in getting the print settings used to create the top layer of a raft for abs (temps, layer height, speed, ect...)? Im printing abs-cf right now, and man it looks amazing.
Temp is constant (275), Layer height = 0,19, speed varies from 10 to 50 (mm/s)
Just print 2 larger items in esun ePA-CF and they came out pretty amazing, standard "hairs" all over but they just rub off (ill try adding more retraction).
I will get photos when I get home.
Setting are as follows:
layer height: .19
extruder temp: 263c (next print i will up the temp to 265-268)
bed temp: 85c
retraction: 0.1 mm/s
retraction speed: 20 mm/s
print speed : -10% ( Dear zortrax, could you please use " mm/s " vs " % " , we should not have to inspect the zcode in order to know what speed we are printing at )
infill: medium
support: 0%
I did have some final quality issues but I believe it was due to how I laid the item out on the bed when slicing.
