Herkese merhaba,
M200 model yazıcı kullanıyorum, program başladıpında raft örme sırasında dişli tekliyo ve raft bozuk yüzeylerden oluşuyor. Bu nedenle model de yapışma oluyor ve sökülmüyor kalibrasyon yaptım,nozzle temizledim. tabla temizledim ve ekstruderin kablolarını kontrol edip söküp taktım ama problem hala devam etmektedir.Yardımcı olursanız sevinirim…
Hi, @Erol.
Please, use English in this forum.
Have you cleaned the platform underneath, as in this manual?
thanks for the advice.
When I encountered this problem, I didn’t clean it as in the manual, but I do the table cleaning at intervals of 6 months. I think the problem is in the title and I couldn’t find a solution. I think I’il have to send it to the service.
Keep in mind that platform should be maintained every 300 working hours, so 6 months is quite a long time.
Have you noticed any issues such as blobs etc. on your prints?
I think that I have solved the problem with a detailed maintenance and my print quality has improved and now I can take parts without any problems. Thank you for your help I will consider your suggestion.
erol bey benle iletişime geçermisiniz zeki dinçer 05357443436
