Hi , please look at he pictures , the M300+ was printing beautiful , but in several occasions and around the same height (even different materials - same part printed) it started to get really bad (underextrusion) any idea what causes it? or how to solve it?
Hi, @userksh14.
Please, check if all cables are properly plugged into the extruder PCB.
It looks like something hooked against the support structures on the right, so I recommend that you make sure whether heater&thermocouple is properly connected to the hotend (as in this instruction).
I don’t see anything wrong in the pictures. As for the cable - have you managed to load the material past the extruder gear? When does it start to click?
hi, right in the beginning ; first I tough it was the filament , then I pulled back a little (not touching the gear) and it started to click again ; the tried again and now it grab it without clicking.
I’ve had that clicking issue with the gear on the m200, where it was turning and clicking but not extruding. The issue was a clogged hotend after about 2000 hours of printing. You can clean it, or replace it if that’s the case.
