Reduction of detachment from the RAFT base
Good morning!
Do any of you have a solution to suggest about the “detachment” from the RAFT plane of my M300Plus with Z-HIPS visible in the attached picture?
my printing parameters are as follows:
Z-HIPS
Layer Thickness 0.19
Infill 30%
RAFT 6 layer
First Layer Gap 0.30
Platform Raft Gap 0.22
Hi. I would suggest decreasing the first layer gap so the adhesion between the raft and the first layer of the model will be stronger. You can also set the fan speed to 0% and decrease the infill level. Most of all, make sure the ambient temperature is quite high (at least 25-27 Celsius degrees), platform calibrated and side covers installed. You will find more information in our guide available here.
