Hello, I use Z-ASA Pro for rather large prints (15x11cm) that are used on a product outside. I chose this material for its UV resistance, although the final aspect isn’t the best available.
My problem is to remove the model from the bed: it’s very very difficult.
And quite dangerous using the knife.
Is there a trick to make the model stick a bit less ? I know that usually we are seeking the opposite, but in this case not !
I just changeg the perforated bed and with a new one, it’s even more difficult.
Actually I have to pass the bed and the model in the freezer…
Maybe I could change of material, but the ASA is the recommended one for outdoor applications, and the material must be white (i.e. no PETG).
Hello Marta, I do wait till the bed is cold, and I use the lastest software.
But on a quite large print like this one, it’s just not enough.
Can a change some layer distance or something ?
You can change platform offset (available in the menu) or platform-raft gap (available in Z-SUITE, see picture below) to increase the distance between platform and raft. I advice that you start with small value (0.05) to see whether it helps.
