Replicate function doesn't works
So I tried to use the replicate function but it doesn't work the first layer on the copies is missing.
This is the original code with the two raft layers correctly generated.
4932
and this is the replicated one the first layer is clearly missing.
4933
Please fix this, the function is great because if processed together the slicing takes longer, and also seams can be different from model to model. But having a non working function like this is not good.
Hi, ahntlia.
Could you pass me the file you have the problem with via PM (preferred .zproj + .zcode)? I couldn’t reproduce the problem, so those files would be very helpful.
